Oppo 980 mod
0 Members and 1 Guest are viewing this topic. Read 1197 times.
MichaelWD
    • Twisted Vista
Oppo 980 mod
« on: 3 Jul 2008, 11:41 am »
I grabbed some caps and sorbothane for doing a mod on an Oppo 980 DVD player (which is an excellent HD CD player), and wanted to know if anyone knows how to make it output a progressive component video signal from PAL/region 2
discs. I'm having a technician do the work, as I lack soldering skills.  Also, I'm planning on adhering a metal base to it (I thought 3/16" steel cut by a local welder would work); can anyone suggest the best way of gluing it to the plastic base of the Oppo unit? The 980 has a very shallow feet; would anybody recommend just carving them off, or cutting the sheet of metal so that it doesn't interfere with the small feet it was built with?
Jampot
Re: Oppo 980 mod
« Reply #1 on: 3 Jul 2008, 08:08 pm »
Did  you ry the region 2 / PAL discs?
It has been a while since I checked the specs but I have bought one because I understood it to be 'truly universal'. That is it palys all regions and all video standards. I hope that is so because I am a UK resident and have the player in US at the moment.
Jim
