Bryston universal remote
0 Members and 1 Guest are viewing this topic. Read 2477 times.
alexone
« on: 3 Jul 2008, 01:04 am »
 james,
 did you guys thought about a programmable remote? now that there are the bcd1, bda1 and soon the sp3 it might make sense to
 have a 'all in one' Bryston remote?!
 furthermore it would be a nice gimmick for us...
alex.
denjo
Re: Bryston universal remote
« Reply #1 on: 3 Jul 2008, 01:17 am »
My understanding is that a Byston remote (say BCD-1) is programable to enable the remote to operate other Bryston equipment (pre, power, processors). There is also the trigger-in function which allows you to control respective Bryston gear. This is my limited understanding but I am sure James will chime (as he always does) with more info ....
alexone
« Reply #2 on: 3 Jul 2008, 01:56 am »
 yes, the bcd1 rem is able to control other Bryston equipment but the rem of the bda1 cannot do the same...( as far as i know).
 i thought of a controller that is a bit more versatile. for example that it can choose between several inputs on the
 bda1 and/or the sp3- just to name a few functions.
Phil A
« Reply #3 on: 3 Jul 2008, 01:57 am »
Per Bryston's site the CD remote can:
"CD remote operates other Bryston products volume up/down/mute"
  • The Demo is Everything!
    • http://www.bryston.com
« Reply #4 on: 3 Jul 2008, 10:35 am »
 james,
alex.
Hi Alex,
We are working on a Universal remote for the BDA-1 that will be able to be used with all our gear except the SP3 - which is a bit to specialized.
I have a PDF of the layout if anyone wants.
james
