Creek OBH 12 with Remote 199 obo
0 Members and 1 Guest are viewing this topic. Read 1444 times.
polishpowerlifter
« on: 2 Jul 2008, 06:19 pm »
Preamp and power supply in good condition with barely a mark in sight. The remote is looking a little old cosmetically but certainly works like new as far as controlling the preamp.
The function of the Creek OBH-12 passive pre-amplifier is to provide input selection and volume adjustment to a Hi-Fi system from an armchair via infra-red remote control. The unit can also be controlled directly from the front panel.
The OBH-12 consists of a high quality motorised volume potentiometer and two stereo relays which select the desired input plus tape output together with a muting relay that can short the signals to ground.
A built-in micro-controller decodes the infra-red signals transmitted by the handset and translates them into commands which activate the motorised potentiometer and the muting and input selection relays.
After each operation the micro-controller turns itself off to avoid any possibility of interfering with the main music signal. LED’s are used to indicate the status and mode of operation.
The OBH-12 is purely passive and does not introduce any gain or distortion into the signal path. It is therefore suitable to be used as a control pre-amplifier provided the sensitivity of the power amplifier that is being used is high enough to be driven directly from the source. i.e. CD player or tuner etc.
The volume control can be operated manually at any time whether the OBH-22 is powered or not but without power only Line 1 can be utilised.
I have the boxes (less the packaging materials) and operating instruction . I will ensure the equipment is properly packaged.
