0 Members and 1 Guest are viewing this topic. Read 4181 times.
2. Are the WAV or MP 3(FLAC) buttons on the left side of EAC main screen equivalent to F6 and Shift F6 respectively?
I could see some difference. Process I am following is Insert CD-> Populate screen with CD information -> F4 to detect Gaps -> Create CUE sheet -> ( Shift) F6 so instead of (shift) F6 can I use the Button WAV or MP3(FLAC)?
3. Is CUE sheet required if I intend to rip my CD into individual tracks?
4. How to specify path to store CUE sheet along with the track files, at present EAC is saving all CUE sheet ( ACTION-> Create CUE sheet..) in root directory. That is for example: a ripped CD album is stored at C:\Music\artist\album while CUE sheets are stored in C\Music
5. Sometime EAC won’t generate a CUE sheet and there is no error message either.
6. I heard that FLAC file has CUE sheet embedded in it, but when I play a FLAC file using Foobar2000 it displays ‘No embedded CUE sheet’, what is happening?
7. If I rip with FLAC , EAC first creates a WAV equivalent and later (user specified Option) deletes it after converting it into FLAC. Is this intermediate WAV is equivalent to WAV created is the normal way? I want to rip some CDs in both WAV and FLAC so if the answer is YES then this would save my time.
