bugle's power supply
0 Members and 1 Guest are viewing this topic. Read 1556 times.
beto1
« on: 2 Jul 2008, 02:50 am »
hi,
bugle's power supply can be configured to 220v?
Best regards
hagtech
Re: bugle's power supply
« Reply #1 on: 2 Jul 2008, 07:18 am »
Yes, wire the primary coils in series.  The holes are arranged in a line "12 34".  Connect pins 2 and 3 together, then apply 230Vac to pins 1 and 4.
jh
beto1
« Reply #2 on: 2 Jul 2008, 10:58 am »
Hi,
thanks for your response.
Do you know that if I configure the PS to 230v having a 220v mains give any performance difference?
regards
hagtech
« Reply #3 on: 3 Jul 2008, 03:12 am »
There is enough headroom in the design to work to work over a much wider range than 220V to 230V.
jh
