BP25 power supplies-MPS-1 wanted
0 Members and 1 Guest are viewing this topic. Read 1561 times.
mitcho
« on: 29 Jun 2008, 04:28 pm »
is there a lot of difference between the original power supply and the MPS-1 that came out later?   Is there a lot of sonic / performance differences?  can the MPS-1 still be purchased?
« Last Edit: 30 Jun 2008, 06:51 am by mitcho »
smerlas
Re: BP25 power supplies-MPS-1 wanted
« Reply #1 on: 30 Jun 2008, 08:56 pm »
You may want to just purchase the new Bryston power supply (MPS2).  The BP26 is primarily a cosmetic upgrade of the BP25 combined with the new power supply.  So if you need a new power supply I recommend buying the MPS2 and if you want you can upgrade the cosmetics as well for the BP25.
The following is a link to Bryston's information on the cosmetic upgrades.  http://www.bryston.ca/pdfs/07/BP25toBP26.pdf
This way you get the latest Bryston has to offer in sonics with you preamp.
You just have to make sure the MPS2 is ordered for use with a BP25, Bryston configures the power cord differently for the BP26 and BP25, but the new MPS2 will work with either one.
SFOX
« Reply #2 on: 14 Aug 2008, 11:29 pm »
mitcho
I just purchased an MPS-2 for use with my BP-20 and am looking to sell the MPS-1 if you still require one
