Audio/Video Gear and Systems
The Acoustics Circle
Rob Babcock
Cheap bump for my TrueRTA question.
0 Members and 1 Guest are viewing this topic. Read 1377 times.
JakeJ
Volunteer
Triode love
27 Jun 2008, 09:43 pm »
This is a cheap bump and to check if someone monirors this circle but not the Lab where the link takes you. If you think there is something better point me to it.
http://www.audiocircle.com/index.php?topic=57177.msg503479;topicseen#new
Jake
Ethan Winer
Industry Participant
Audio expert
Re: Cheap bump for my TrueRTA question.
28 Jun 2008, 01:07 pm »
How are you connecting to your computer's sound card? With that much noise, it sounds like you're using the microphone input, and/or you have the microphone input set for an extra 20 dB of gain.
--Ethan
dyohn
Reply #2 on:
7 Aug 2008, 05:36 pm »
Were you using a microphone preamp?
Rob Babcock
