0 Members and 1 Guest are viewing this topic. Read 5145 times.
If it's heavier than Lodge you'll need 2 people to use it.
The pans Dan linked to are 6" & 8" & 10" and Amazon shows a shipping weight of 12 pounds for the three of them. Bob
Anyone got any recommendations on a cast iron fajita skillet? I don't own any cast iron currently, so a complete newb here!
Cast iron is really a necessity if you like to grill. They handle the heat all day with nothing to worry about. They are great on a gas stove, also (when seasoned properly).Wayner
Wipe the pan with meat fat (oil is a poor second) and heat in the over at 200 degrees for a couple of hours. Never wash with soap, take care to not overheat when empty. Re-season as needed.
Quote from: S Clark on 21 Jul 2008, 12:52 pmWipe the pan with meat fat (oil is a poor second) and heat in the over at 200 degrees for a couple of hours. Never wash with soap, take care to not overheat when empty. Re-season as needed.Thanks. How do you wash it if you don't use soap?Joe
