How long for Power Cable Burn in?
0 Members and 1 Guest are viewing this topic. Read 935 times.
kbuzz3
« on: 23 Jun 2008, 08:48 pm »
Ive got a new PC hooked up to my cpu/monitor for burn in.  Any idea what would be a decent amount of time before I give it a whirl?  Im guessing a week but not quite sure.  thanks in advance
boead
Re: How long for Power Cable Burn in?
« Reply #1 on: 23 Jun 2008, 08:50 pm »
250 - 500 hours.
zmanbands
« Reply #2 on: 23 Jun 2008, 09:34 pm »
Leave the component powered up. Listen in 2/5/10/15/20/30 days. Take notes. By 30 days it should be settled in. This is what my PC manufacturer suggested. Your PC could respond differently.
TheChairGuy
« Reply #3 on: 24 Jun 2008, 12:36 am »
Depends....teflon dielectric takes the most time...varying differences in grades of teflon dieletrics take different time to settle in.
Poly and cotton take nearly zero time I've found.
I don't think it's the wire breaking in too much at all (perhaps a bit - less than 24 hours), it's the interaction between dialectric and wiring that takes all the time up.  The thinner the dialectric (a la magnet wire and even Alpha-Core cables), the less break-in time needed.
Regards, John
