Benchmark DAC1 USB
0 Members and 1 Guest are viewing this topic. Read 1105 times.
geowak
Benchmark DAC1 USB
« on: 20 Jun 2008, 09:20 pm »
Is anyone out there using the Benchmark DAC1 USB as a preamp? I know that it can be used as a stand alone pre, but just don't know if it gets high marks, as far as the fidelity goes.
Panelman
Re: Benchmark DAC1 USB
« Reply #1 on: 20 Jun 2008, 10:07 pm »
I've used both the DAC 1 USB and DAC 1 Pre(current preamp) and think they are both very transparent and are both very good. The flexibility in the digital inputs is great if you have multiple sources and like to use a laptop to play hi-rez files that a Squeezebox cannot play.  With the DAC 1 you get a very good flexible DAC that allows you to remove a layer of interconnects. There is no remote, that's the only drawback IMO.
