Tubby Tone 10" Bass Driver
0 Members and 1 Guest are viewing this topic. Read 4291 times.
ttan98
« on: 20 Jun 2008, 10:03 am »
I am thinking of using this TT Bass Boy as a bass unit in a vented enclosure. It has the following paramenters:
10" Bass Tone Tubby 8 Ohm Speaker Specs
Driver Properties
Name: TT Bass 10
Type: Standard one-way driver
Fs = 63.8 Hz
Fsa = 42.7 Hz
BWs = 81.4 Hz
Vas = 48.4 Liters
Cms = 2.82E-04 m/N
Mmd = 18.3 g
MMr = 3.76 g
BL = 11.1 Tesla/m
Eta = 2.61 %
Qms = 1.69
Qes = 0.46
Qts = 0.36
Re = 6.400 Ohms
Zmaxs = 29.7 Ohms
2.83-V SPL = 97.1 dB
1-W SPL = 96.2 dB
Kr = 0.000
Xr = 0.000
Ki = 0.000
Xi = 0.000
Can any tell me the difference between the Fs and Fsa quoted above? What is the real resonance frequency?
Thanks in advance.
The unit only costs $105 after discount, not bad price.
painkiller
Re: Tubby Tone 10" Bass Driver
« Reply #1 on: 24 Jun 2008, 08:39 am »
Where did you get those specs? I'd really like to get specs for the 15" version, but Tone Tubby seems to keep it to themselves. Wonder what the Xmax is.
Fs is the "real" resonance frequency. Fsa is the lower resonance frequency with added moving mass, which I never understood the point of.
iON
« Reply #2 on: 24 Jun 2008, 10:18 am »
painkiller: TT used to have the t/s published on their website, Try archive.org.
ttan98: Fs is probably the one you'll be interrested about. (A guess would be that If they've used delta mass method to compute the t/s parameters Fsa may be the resonance frequency with added weight)
Cheers!
ttan98
« Reply #3 on: 24 Jun 2008, 10:41 am »
painkiller,
the archive webpage does not include the spec for the 15".
scorpion
« Reply #4 on: 24 Jun 2008, 09:51 pm »
You won't get much (any) low-bass out of that element in a VB.
Bass speakers should be considered in order: IB, OB and CB and ...........
/Erling
painkiller
« Reply #5 on: 25 Jun 2008, 06:41 am »
But a low Qts driver in an OB. How does that work? Perhaps one could get some bass output by placing the driver close to the floor, using side braces and perhaps some stuffing?
scorpion
« Reply #6 on: 25 Jun 2008, 11:27 am »
The last sentence was meant more like a general remark of my personal preference for bass-pruduction.
This Tone Tubby bass won't do it for Hi-Fi in any kind of (non-) enclosure but will probably be OK for guitar in VB.
/Erling
painkiller
« Reply #7 on: 26 Jun 2008, 08:07 am »
I'm in dialogue with A Brown about a custom 15" Super Boy for OB. They seem positive so far, but we'll see.
painkiller
« Reply #8 on: 27 Jun 2008, 05:59 am »
I finally managed to get the 15" specs from A Brown.
Nom. diamerer [inch] 15
Vas [Liters] 260
Qts  0,3
Qes  0,31
Qms  13
Fs [Hz] 43
Sensitivity [dB] 101
Max Power [W] 400
Lower freq [Hz] 60
Upper freq [Hz] 3500
xmax [mm] 3,25
Moving mass [g] 48
Disp area [m2] 0,086
xdamage [mm] 12,5
Coil diameter [mm] 62,5
Cms [mm/N] 0,214
Rms [N*s/m] 1,4
Magnet weight [gr] 2,225
Re [ohm] 5,2
Z [ohm] 8
Crazy sensitivity there. A bit lower Q, and lower Fs. Any way one could make this work in an open baffle? I guess the 16 ohm version would have a bit higher Q?
ttan98
« Reply #9 on: 27 Jun 2008, 06:47 am »
15" woofer has been used as mid-bass driver in an open baffle configuration before, eg being Bastani open baffle, the bass driver(15") is a separate unit driven by a solid state built-in amplifier in a sealed enclosure.
I don't know the specs of both drivers.
dewar
« Reply #10 on: 27 Jun 2008, 06:55 am »
I've used Qt 0.29 12" Peerless drivers in OB and did not have the use the DEQ2496 it was running through for anything else than pulling down a peak, but this was with a 30hz room node helping out, and biamping, which makes sensitivity largely moot.
Maybe have a read of the Jamo OB whitepaper. They used lowish Q bass drivers but of much higher sensitivity than the midrange drivers and a coil on the bass drivers to achieve a net flat FR and sensitivity match, if I remember. (Havent read actual paper myself).
