tweeter selection-Aurum Cantus G1 or Eton ER4?
0 Members and 1 Guest are viewing this topic. Read 3280 times.
jtwrace
    • TIPP YouTube Channel
« on: 19 Jun 2008, 07:47 pm »
I went to order some Raven R2.1 and they are not available anymore.  So, what are your thoughts on the Aurum Cantus G1s or the Eton ER4s?  I will be pairing them with the Accuton C79 and the Scanspeak 18w.
thanks-
TF1216
Re: tweeter selection-Aurum Cantus G1 or Eton ER4?
« Reply #1 on: 19 Jun 2008, 08:13 pm »
You will be pairing the tweeter in separate speakers each one using a different midrange?
How about a tweeter from Raal?
www.raalribbon.com
kyrill
« Reply #2 on: 20 Jun 2008, 09:36 am »
 I have G3 ribbon s( a bit less longer than G1)  experience
i would recommend Raal,
they have a much more reliable and thought of system
to replace a ribbon. It is really fool proof
also their ribbons are much less prone to "over" excursion
than the G1 because of their design.
jtwrace
« Reply #3 on: 21 Jun 2008, 12:19 am »
thanks for the feedback.  I've settled on the Fountek 2.0.  I will try them.
