0 Members and 1 Guest are viewing this topic. Read 8697 times.
"could set crossover formally to 125-150 and have flat response up to around 300 Hz for the next crossover." Hmm, if i read you well, does this mean if i set Xover on the bassamp to 150, the drivers will continue f l a t to 300? How is this?
Guitarretypethx for yr photoos. To me a picture is more clear than many words. So yr "embedded" U design made me happy. Danny warned me to make the "U" frame not too deep in order to avoid cavity resonances. I saw at yr photoo the "U" is not too deep but why do people not make the two free legs of the U not slightly unparalleled for that reason?On the sensitivity graph of the audiom they are flat to under 100hz with sensitivity of 92db. they are rated 100W-200W. Does yr warning means, that on higher levels (at 100hz) the driver becomes less sensitive, so needs more power than say, 300hz for the same loudness?
