Replacement speakers
0 Members and 1 Guest are viewing this topic. Read 2836 times.
Andrew Hallam
« on: 31 Oct 2003, 01:19 am »
I have 4 older Advent Heritage speakers that I use as part of my home thater system. The 8 inch woofers are starting to dry rot and the foam is coming off around the outer edge. What would be a good replacement speaker and where could I purchase them. Thanks,
Sean Parque
    • http://www.av123.com
« Reply #1 on: 31 Oct 2003, 07:28 pm »
Hi Andrew.  You will get a better response if post in the general section of the Audio Circle rather than here which is for a specific manufacturer.
Sean
Mad DOg
« Reply #2 on: 31 Oct 2003, 09:52 pm »
Sean,
You may want to move this thread to another circle...
Sean Parque
« Reply #3 on: 31 Oct 2003, 09:56 pm »
removed as it is no longer relevant :)
Tonto Yoder
« Reply #4 on: 31 Oct 2003, 11:19 pm »
Andrew,
Assuming you're happy with the sound/size of the Advents, why not have them refoamed or foam them yourself??
http://yp.yahoo.com/py/ypMap.py?Pyt=Typ&tuid=16351600&ck=4029946351&tab=B2C&city=Naples&state=FL&country=us&msa=5345&cs=4&ed=8z7pGa1o2TxMoi4ucgMxH1wmaz8gyTasSc4jIsrH_AvI&stat=:pos:0:regular:regT:1:fbT:0
There are two companies in Fla. that offer DIY foam at about $20/pair; check eBay.
Andrew Hallam
« Reply #5 on: 1 Nov 2003, 03:16 pm »
Thanks for your help. Sorry I posted on the wrong board.
Sean Parque
« Reply #6 on: 4 Nov 2003, 10:52 pm »
It's no problem at all...
Sean
