0 Members and 1 Guest are viewing this topic. Read 2858 times.
HiI thought I can be a reasonably good audiophile, but my system proved it wrong. I am still at the starting block. My problem runs as follows, but first about my system:AV Receiver - Yamaha RX 556Front LR Speakers - Paradigm Monitor 9Center Speaker - ParadigmSurround LR Speakers - Infinity Renaissance 9Subwoofer - AR S10Stereo Amp - Sansui AU X11CD Player - DenonI have connected the TV cable receiver through the AV receiver which already has the 5.1 setup, however, unless I increase the receiver's volume to 40 DB, I can hardly hear anything through the speakers. I had previously run the TV cable through the Sansui phono input & the front LR speakers & boy, it is clear!Is there anything I am doing wrong? The Front LR speakers are set to small because I want the lower frequencies going to the sub, the sub crossover is set to 60Hz because even if THX certifies 80Hz, 60Hz is the maximum lower frequencies can be heard best with a sub. The connecting wires have all been double checked twoce, bought them from Brisbane last year & I have done bi-wiring.What can be the problem with my receiver set up? Forgot to mention that although the Sansui tends to be a bit bright, I would never trade it for any other amp for stereo. It's a true audiophile classic.Would appreciate any input. Thanks!
