piccolo resistor question
0 Members and 1 Guest are viewing this topic. Read 1785 times.
alpa6
« on: 18 Jun 2008, 05:04 am »
Im about to finish up my piccalo r 10 has two values in the manual.One schematic says 221.This is what i put in it.The parts list says 232 should go there.Which is right? Their pretty close in value does it matter?
alpa6
Re: piccolo resistor question
« Reply #1 on: 19 Jun 2008, 03:32 am »
no one built a piccalo yet?No one see the problem in the manual?The parts list says 232.The resistor schematic says 221.What do i put in?I already put 221's in there.
Jim you there? whats the right value?I want to finish it up tommorow.I guess i could try what i have in there now.It within 10% of 232 but id like some guidance.
hagtech
    • http://www.hagtech.com
« Reply #2 on: 19 Jun 2008, 05:10 am »
Put in the 232.  It was a late change to the design.
jh
alpa6
« Reply #3 on: 20 Jun 2008, 02:35 am »
Oh my i think i killed my piccolo.I accidently put s1 into s2.In order to get it out i pulled out a trace.I reinserted it and got solder on it so i got contact.Only one side works now.The other side is very low in volume.Mostly i just get tube rush.The light does not come on.Ive measured all the resistors around s1.All the resistors come out  similar.Any ideas what i might do to check for whats wrong?The left sides  the bad one.I was able to connect the trace with solder and it is getting voltage.
alpa6
« Reply #4 on: 20 Jun 2008, 02:45 am »
I was able to connect the exposed wire with solder.I measured the exposed wire and do have voltage there.
