0 Members and 1 Guest are viewing this topic. Read 4289 times.
Here is a link to one that I have found http://www.rivesaudio.com/software/softframes.html
Guy,Moving the speakers even a few inches or less (especially movement out from front wall) has a dramatic effect. If you could even borrow someone's Velodyne SMS-1 (some have it as 30 day return policy...but I'm not advocating anything... ) and run it realtime, while moving the speakers, you'll see realtime response (under 100k) on your tv or projector. Then you could then go back to finer details of ETF or REW and do the tweaking. My $.02Are the 10hz-wide measurements averages you took here? You should likely see spikes within one hertz or so as you approach modes.
are you saying to move the speakers a couple of inches and remeasure then repeat this step over and over?
..Makes me wonder whats above 300hz And the journey begins, more to come.
