Practicality of using 3 centers across the front?
0 Members and 1 Guest are viewing this topic. Read 2167 times.
rasmussen
This is a set up I've wondered about off and on for some time. I am re doing the stereo/home theater area with new cabinets and going back to stereo for the subs. The last time I used a pair of subs was after the Forces just came out. I have a moderate size room. My interest in using a pair of centers for main left and rights is partly cosmetic. I envision a slab of maple or cherry in a low table type set up maybe 16-18 inches wide and 20 inches high to hold our plasma moniter and running about 8 feet long. Instead of putting stand mounted satellites just in front of the table it seems like it could work quite well to place a couple of 6-12 inch stands bringing two center type speakers up to ear height a foot or so above the table.
Anyone try this set up or have a comment? I'd be looking at something about the size of the Saphire XCL with tweeter above mid as a basic requirement for the center design. The ACIs could be a  possibility or perhaps the paradigm C-3 signature. Ive got a pair of the small paradigm S1 satellites and they are quite good but I think ultimately I'd like to have just a bit more bass to bring the crossover down a bit.
Any thoughts or experienes aprecciated,
Larry R,
Seattle
Mike Dzurko
Re: Practicality of using 3 centers across the front?
« Reply #1 on: 16 Jun 2008, 12:41 pm »
Larry:
We actually designed the XLC with this in mind. All final listening testing was done as stereo pairs. It makes an excellent setup.
rasmussen
« Reply #2 on: 17 Jun 2008, 12:29 am »
Thanks Mike, you could probably guess that I am reading the on line tip series you all put out by email. Do you use them traditionally otherwise, raised for tweeter about ear height and toed in to taste?
I have to say that it's nice to stop in and find ACI to have some of the same personal style or personality it did when I used to wear your catalogs out so many years ago just reading them over and over and planning the system I'd get when I finally got some money accumulated.
Larry R
Seattle
Mike Dzurko
« Reply #3 on: 18 Jun 2008, 12:15 pm »
Larry R
Seattle
 Larry:
 Well they say old dogs don't change much   :lol:   Ideally the three speakers would be as close to ear height as possible. Putting them right under a projection screen works really well. If they are a bit low, then tilting them up a bit is just what the Dr. orders.
mfsoa
« Reply #4 on: 18 Jun 2008, 12:52 pm »
Conversely, why not use a single conventional L or R speaker for the center?
Just a thought
Mike Dzurko
« Reply #5 on: 18 Jun 2008, 01:46 pm »
Just a thought
It's a great thought   :D  A lot of our customers opt for a either three Sapphire XLs across the front or three Emerald XLs.
