0 Members and 1 Guest are viewing this topic. Read 6679 times.
I'm considering making my own umbilical to run between my VAC and VDA. I can't justify $100 bucks for the Revelation gizmo since I don't even think I paid that for either component on the used market.
Here's what I'm thinking. Dusty let me know what size plug I need and I found a Switchcraft plug that will do the job. I was thinking about Venhaus unshielded twisted pair for the cabling. I would think shielding would be great, but since there is nowhere to ground the shield to, I don't know if it would be worth it. I'm also considering pulling the plugs out of the VDA and VAC and hardwiring the cable between them (they are both cracked, as they seem to do a lot).Any thoughts? Comments? Suggestions? Worth it?Thanks for your advice guys.
Hmm, that link was informative. Maybe I could pull both the jacks, hardwire in a shielded cable, and ground the shield to the IEC ground on the VAC-1... How sensitive is the VDA to being placed very close to the VAC? Any benefit to separating them? Or would stacking be a problem?
Yeah, I was considering stacking with about a footlong umbilical between them. I wish I had the right size allen wrench to crack the VAC-1 open and take a look inside to get a better idea.
That's weirtd... I don't have any hum issues yet, sounds like some sort of digital amp nastiness.
I had a serious issue with VDA / VAC placement recently. The VAC was making very audible 'crackling' noises, and audio was jumpy. I had to move the VDA to a lower shelf on the rack. Very odd, as they worked fine right next to each until I got new amps - ciaudio amps in fact!
Thanks Dusty. Any thoughts on shielded vs. unshielded cable for the umbilical? It would be no more than 1 foot, so I don't know if it's critical, but you know a lot more than me, which is why I buy your stuff instead of the other way around.
Can I also ask, a couple of you guys have mentioned cracks to your cables, can you expand on this a little bit please? What do you mean by cracks? Is the Umbillical very fragile and split at the slightest touch?
