Is Cold Brewing Coffee common?
John Casler
« on: 15 Jun 2008, 04:36 pm »
Recently I tried "Cold Brewing" my coffee.
I have one of those plastic filters and don't wish to have a coffee machine on my counter evaporating coffee and burning electricity for hours.
Since I generally only drink a single cup, I placed the grounds in the filter, placed it in a large coffee cup, and added cold water.
Next morning, I took out the filter, microwaved for 60sec, and had a very smooth and rich cup o'joe.
I got the idea, from the way I do my Green Tea.  I simply place the bag(s) in a cold cup of water for tea the next morning.
Tastes fine, seems a little "greener" since it is less electricity, and it certaily tastes fresh instead of "washed out" especicially for that second cup.
I also experimented yesterday, with a "double" use of the grounds, (meaning I made a second cup from the same grounds) and just let the cup set for 1 hour, and the same results, compared to a second cup from a percolator, that has been setting for hours :?
In any event, I can't see doing any other way right now.  Seems like a good alternative if you only drink a cup or two each day.
Probably would work even better if you were into "iced coffees" which I am NOT :nono:
bummrush
Re: Is Cold Brewing Coffee common?
« Reply #1 on: 15 Jun 2008, 05:26 pm »
Makes it less acidic and smoother.
pedrillo
« Reply #2 on: 15 Jun 2008, 07:14 pm »
I am into health and learned to make coffee like this a while back. It especailly is healthy for you if you use energized water.
KKM
« Reply #3 on: 15 Jun 2008, 10:17 pm »
There are different reactions when introducing heat to any food. Sometimes it dissipates some of the volatile flavors that could be preserved with a cold process. Other times, heat improves the flavor, such as carmalization or the technical term Malliard reaction. This is very dependent on the type of food.
Dan Driscoll
« Reply #4 on: 16 Jun 2008, 03:46 pm »
If the point is to reduce your electrical usage, I doubt making coffee this way has any significant effect. Just turn off or unplug the coffee maker off once it has finished brewing and I suspect the energy usage will be the same as for running the microwave using your method.
DaveC113
  • ZenWaveAudio.com
« Reply #5 on: 16 Jun 2008, 04:04 pm »
The Brewing Market chain here in Boulder, CO uses this method for iced coffee.  It comes out as a concentrate that they dilute 1:1 or so... it is very good, but they charge a lot for it because it uses a lot of coffee beans per cup compared to regular brewing.
I prefer to use a stovetop espresso maker, a stainless steel Bialetti model.
KS
« Reply #6 on: 16 Jun 2008, 08:42 pm »
Toddy Products commercialized cold brew coffee 44 years ago.
I don't like it.  Some of the flavor is missing...or at least different...and not to my liking.
