0 Members and 1 Guest are viewing this topic. Read 4460 times.
I have or have had both, and the Tokina 12-24 and the Nikon 12-24/4. The 14-24/2.8 is pointless on a D80, it's meant for the full-frame D3 (and it IS stunning on a D3). The Sigma is a nice lens, so is the Tokina, but the Nikon DX wide-angle is worth the extra $$$. Now before you write that off as Nikon elitism, know that I dumped my Nikon 28-70/2.8 for an optically superior copy of the Tamron 28-75/2.8 ... and my primary sports lens is the Sigma 120-300/2.8
Regarding wide-angles and low-light, the great thing is with steady hands you can get sharp shots hand-held at shutters as slow as 1/3 sec at 12mm. That makes max aperature much less important, and DOF at 12mm is about 5 miles anyway Enjoy the Sigma, it's a good lens as long as you get a good copy. But if you get one that's off send it to Sigma, don't return it. Chances are you'll get a better lens if it's recalibrated by the factory than you will with a new lens. I've had a couple lenses recalibrated by the factory, one Sigma and one Tamron, both came back stellar.
I've never tried the Tokina, but I'm borrowing the Sigma 10-20 from my friend right now and it definitely has some of the best build that I've handled.
I'm not sure how much use you guys really have with all the wide-angles, but I can say that I've exhaustively compared them all - the Sigma 10-20, Tamron 11-18, Tokina 12-24, and Nikon 12-24. Actually I've had 3 copies of the Sigma, 1 of the Tamron, 2 of the Tokina, and 2 of the Nikon. As a Pro shooter I cannot accept lenses with any unusable ranges, and the only one that I felt comfortable using in any aperature/focal length setting is the Nikon. It's also the only one who's focus was 100% guaranteed to be spot on. Of the group the Tamron was the loser, it couldn't lock on focus for anything, and the outer 1/3 edge of the frame at anything under f/8 were horrid at 11mm. The next loser for me was the Sigma, it had the worst CA of any lens I've ever seen, completely unfixable in post processing. The only way you could avoid the CA was to stop it down to at least f/8 when shooting 14mm or wider. The edges were also heavily distorted and much less sharp than the center at 14mm or wider and any f/stop. The Sigma does have decent build though, and it's focus accuracy and speed was 2nd to the Nikon. Another big minus for the Sigma is a variable aperature. The Tokina was closest to the Nikon optically, the Nikon being only slightly sharper at the edges when wide open or near it - when stopped down they were both equals. Another area the Nikon beats them all is color and contrast, the Nikon easily being the most saturated of the bunch, the Tokina had the least saturated images especially when wide open.I'd have to question the experience or impartiality of anyone who says the Sigma beats the Nikon by a long-shot, that's simply not true. Of the bunch the Nikon is the only lens I can use anywhere across it's range, in any light conditions, and not worry about results or the lens' sweet spot. All the others have weaknesses you must be aware of and work around the get good results.
