Cornet 2 - RCA Jacks question
0 Members and 1 Guest are viewing this topic. Read 2208 times.
643nana
« on: 13 Jun 2008, 08:05 pm »
Hello,
I have a question about how to connect chassis mounted RCA jacks. I want to put chassis mounted RCA jacks instead of PCB mounted RCA jacks. There are 5 holes on PCB for RCA jacks. I think 2 holes for mounting and 3 holes for PCB mounted RCA jacks. Is there anyone knows how to connect from PCB holes to RCA jacks? I don't know which hole is for + and -.
I need a help! Thank you.
Bill Epstein
Re: Cornet 2 - RCA Jacks question
« Reply #1 on: 14 Jun 2008, 09:59 pm »
The 2 big holes are for mounting tabs, ignore.
The small center hole in the middle is ground.
Looking at the board so the lettering is right-side-up, with the mounting holes at the top, or away from you, the right hole, which is on a line is right, the left one, left.
643nana
« Reply #2 on: 15 Jun 2008, 05:15 am »
Thank you, Bill Epstein.  :D
