Candela question/help
0 Members and 1 Guest are viewing this topic. Read 1812 times.
malus15
« on: 10 Jun 2008, 09:33 pm »
I've had my Candela now for 6 months or so and it's pretty sweet. However a few days ago I went to turn it on and it didn't "click" over after waiting the usual 30 or so seconds. I turned the unit off and back on again and it worked.
Today I tried to use it and it didn't click over at all. The Odyssey light is lighting up, the tubes both appear to be lit, what's the deal? No sound!  :duh: Is it a fuse? Any help would be great, thanks!
Bigfish
Re: Candela question/help
« Reply #1 on: 10 Jun 2008, 09:41 pm »
I recommend that you send AlexG a PM with your telephone number and he will get back to you.
Good Luck,
Ken
bpape
    • Sensible Sound Solutions
« Reply #2 on: 10 Jun 2008, 09:50 pm »
Sounds like just a bad relay but Alex would be the best one to speak with about it.
Bryan
