Symmetrica Info and Pictures
0 Members and 1 Guest are viewing this topic. Read 9246 times.
cadobhuk
Re: Symmetrica Info and Pictures
« Reply #20 on: 30 Jun 2008, 04:36 am »
That would make $2.7k for the ribbons alone
Rick Craig
  • Selah Audio
    • http://www.selahaudio.com
« Reply #21 on: 30 Jun 2008, 12:20 pm »
Hi Rick,
You using the NeoPro 5i ribbons in these?
No but that certainly would be possible.  :thumb:
jphaggar
« Reply #22 on: 6 Jul 2008, 08:23 am »
Rick
What are the dimensions and weight of those beauties and their subs ?
jp
Rick Craig
  • Selah Audio
« Reply #23 on: 7 Jul 2008, 03:54 pm »
Rick
jp
The single 12" sub base is about 14" square. The array height will be 56"-60" tall depending on the configuration, 12" wide, 8-9" deep. The sub will be 60-70 lbs. each and arrays 90-95 lbs. each.
