7B SST parallel configuration
0 Members and 1 Guest are viewing this topic. Read 1264 times.
Sasha
« on: 9 Jun 2008, 09:10 pm »
Is the reconfiguration from serial to parallel user configurable?
I understand older 7B had an outside switch, 7B SST C-series is factory wired, but is this something I could do?
Nothing really wrong with present configuration, just for the sake of trying, to see what sonic difference it may make?
  • The Demo is Everything!
    • http://www.bryston.com
Re: 7B SST parallel configuration
« Reply #1 on: 9 Jun 2008, 09:39 pm »
I will check -I do not believe it is something that can be done outside the factory.
james
