TL7 transmission line single fold series
0 Members and 1 Guest are viewing this topic. Read 3664 times.
RAW
« on: 6 Jun 2008, 01:59 pm »
Over the last few months we have been working on a new transmission line models.Our new TL7 series speaker kits are designed with a single fold D'Appolito configuration (MTM), but with an internal tapered transmission line alignment venting through the open rear of the box.This model uses a pair of modified SDX7 woofer matched with our ribbon also offered with the OW4 dome tweeter for those who would like the dome tweeter. We have done some modifications to the carbon fiber cone on the SDX7 woofer which change the driver greatly for what we want.These modifications to the cone of the SDX7 woofer, change the complete characteristics of the sound from the SDX7 for a positive result to say the least.
Mirror image left and right speaker this is also done by moving the woofers as close as possible to load the cabinet as equal as possible.
Expectations from the TL7 low bass extremely accurately with a tight positive feel never lacking lower bass,there is NO boomy bass from this design.
First off the TL7 R (ribbon) measurments
TL7 R response showing the crossover point
With the TL7 series using a off set tweeter, mirror image right and left speaker there is a difference in the off axis response differrence  .This is due to the tweeter is closer to one edge of the baffle which is shown in the measurments below marked left and right.
Off axis measured to the left when looking at the TL7 R speaker with the tweeter on the left side of the TL7 R speaker as you look at the speaker.
Off axis measurements to the right when looking at the TL7 R speaker with the tweeter on the left side of the TL7 R speaker as you look at the speaker.
Spectral decay very clean
Impedance has a low point at the crossover point.Not a issue for amplifiers running 4 ohm load
Shown impedance without the correction network
With impedance correction network
Next the TL7 O with the Platinum OW4 dome
Speaker kit $799.99
http://www.rawacoustics.com/item__TL7_R_speaker_kit,885.html
TL7 R speaker kit includes
:: 4- SDX7" XBL^2 drivers (modified cone treatment)
:: 2- RA104.5 ribbon tweeters
:: Solen capacitors
:: 16 gauge air core Inductors
:: Metal Oxide resistors
:: 2-Terminal cups with custom terminal posts
:: wire,screws including Poly damping material
:: Cardas Lead Free Silver Solder
:: cabinet construction plans, PLUS a CD containing complete contruction photos of the cabinets along with the crossover layout plans including photos of assembled crossovers.Additional veneering plus finishing information on the CD.
:: Build your own cabinets.
:: Recommended cabinet dimensions
  Rear ported cabinet tuned to 27hz  44"  tall X 9"  wide X 19.25 deep"
:: Sensitivity is 85 db (1watt/1m)
:: Recommended amplification 50-200 watts RMS
:: Impedance: 6 ohms nominal
RAW
Re: TL7 transmission line single fold series
« Reply #1 on: 6 Jun 2008, 02:11 pm »
TL7 O speaker  is a Mid size tapered single fold transmission line speaker, uses modified SDX7 woofers matched with OW4 Hiquphon Platinum dome tweeter.
Frequency response showing the crossover point
Off axis measured to the left when looking at the TL7 O speaker with the tweeter on the left side of the TL7 O speaker as you look at the speaker.
Speaker kit $879.99
http://www.rawacoustics.com/item__TL7_O_speaker_kit,886.html
TL7 O speaker kit includes
:: 2- OW4 Hiquphon Platinum dome tweeters
:: Solen capacitors
