0 Members and 1 Guest are viewing this topic. Read 17618 times.
John - another question on this .... I'm wondering just how adhesive plasti-clay is. Considering I need to turn the table upside down, stuff it into the plinth underside, and then I turn it back over - it needs to stick to the underside -I don't think I want it falling and touching / stressing any wires or or other "doo-dads," as you say.Ever hear of anyone trying silicone caulk? I happen to have a few tubes of very good stuff (non-acetic, neutral curing - won't corrode metal) laying around. Perhaps it is not as dense a material as plasti-clay, but it'd fill the cavities, and I could dole it out with some precision. Whadda ya think?p.s. Just looked at a tube to see if it specified weight (not) - but it did state the caulk is "specifically formulated for use on vinyl products! Karma?
Most online audio stores sell damping material in sheets they are'nt as heavy as clay but will damp the vibration. Plus it doesnt take up a lot of room. I would be afraid the putty would work loose and fall into moving parts. With that said it is worth experimenting but I would'nt expect fantastic results whether you use damping sheets or clay. Actually, I remember doing the clay thing years ago on a Denon DP 30 TT and it helped, but I ended up selling it and buying a better TT in the end......DK
The SL-1200 plinth is still die-cast aluminum and could benifit from some plasticlay. I plan on doing mine this weekend.Wayner
Silicon seal is not a good choice for a damping material.In keeping with my original 1982 Audio Basics article on the subject, the governing factor is that "meatballs don't bounce". Silicon seal bounces, plasti-clay does not.Also be wary of plumbing substitutes such as mortite, etc. They may contain an acid bass that can corrode wiring.Finally remember the misfortune of the newlyweds who confused Vaseline with mortite. All their windows fell out.Regards,Frank Van Alstine
