What's going on here?
0 Members and 1 Guest are viewing this topic. Read 1477 times.
Mag
« on: 3 Jun 2008, 02:19 pm »
When re-mastering with the BCD-1 the signal is sampled, recorded and converted by ADC. Then playing back on the BCD-1 the signal is processed again.
I believe this works because of the low jitter of the BCD-1. The ADC introduces some jitter back into the recording, but it's then corrected again by the BCD-1.
So my question is, is the signal oversampled 2 times or 3 times in this process?
Are the stunning results from this process made possible because of the low jitter?
  • The Demo is Everything!
    • http://www.bryston.com
Re: What's going on here?
« Reply #1 on: 3 Jun 2008, 02:41 pm »
Hi Mag,
The Bryston CD Player DAC oversamples 128 times and the jitter is below the residual of the Audio Percision AP2700 test gear.
james
Mag
« Reply #2 on: 3 Jun 2008, 05:48 pm »
Is it correct to say then, its oversampled 128 (BCD-1) X 32 (ADC) x 128 (BCD-1) to arrive at the final result?
« Reply #3 on: 3 Jun 2008, 05:52 pm »
Sounds logical.
I assume your finding you prefer the copy even to the original?
james
Mag
« Reply #4 on: 3 Jun 2008, 06:01 pm »
Yes, I find the resolution obtained from less than ideal resolution original recording is the ballpark of DTS.
I'm thinking of trying it on higher resolution recordings that aren't re-mastered. On badly compressed recordings I don't think it would eliminate the compression.
