BP25DA as a Standalone DAC ?
0 Members and 1 Guest are viewing this topic. Read 2939 times.
jethro
« on: 28 Oct 2003, 11:17 pm »
Can a BP-25DA be used like a standalone DAC by routing the "TO TAPE" outputs to a source input  of an SP-1.7 for example ?
If so, is this the general practice for most pre-amps/receivers ? I'm wondering because it would allow me to use an old receiver as a tuner in another system. I could try it but I'm afraid of damaging my gear.
Thanks.
  • The Demo is Everything!
    • http://www.bryston.com
« Reply #1 on: 8 Nov 2003, 12:38 am »
Hi,
Yes if you use the Tape outs you would get the decoded signal from the DAC's.
james
