Owners Agree, Audio Elegance is REAL Furniture For Audio
0 Members and 1 Guest are viewing this topic. Read 1160 times.
osageaudioproducts
    • Osage Audio Products
“If you are or have been a serious audio enthusiast for any length of time, you probably have come to realize that if you look cleanly and closely through all the smoke and mirrors, and all the hype, you can find some diamonds in the rough.  One case in point is Audio Elegance Audio Furniture.  I was so very happy when I stumbled across this line.  The prices seemed almost too fair and my skepticism was high when I ordered my first four amp stands.  I kept thinking that you get what you pay for most of the time, and I'm not paying enough for the quality that I wanted.  To my great surprise, upon receiving my stands, you could have knocked me over with a feather.  The quality of workmanship, fit, and finish was so far beyond my expectations, I couldn't believe it.   Initially, I sought out amps stands for cosmetic reasons alone, but the acoustic benefits of the Audio Elegance amp stands were immediately noticeable.”
- Jeff Carder, Extreme Audio Enthusiast and Audio Elegance James River Collection Owner.
“Not only did my Audio Elegance stands instantly improve focus, soundstage and bass response in my reference system, later, as I  filled the mass loading compartments with varying amounts of lead and/ or zip lock bags of sand, I discovered I could coax each  component- from amp to CDP to turntable-to even greater levels of  performance, or simply to accentuate a frequency range. Most striking is the deep silence between the notes and the extended decay that continues to amaze. Thank you for recognizing that the isolation needs of each component are varied and that a slab of maple isn't the optimum solution for every component. The sky is the limit with your enlightened design. Form and function so rarely meet, but these stands look so good, my system sounds great before I even turn it on!”
- Tony Bender, Audiophile and Audio Elegance James River Collection Owner.
“The custom turntable stand came in Friday and was well packed indeed.  I filled it with sand and lead shot 60/40.  It’s just handsome under my black Rega, and what's most important is that there is a MAJOR improvement in sound quality.  We're very impressed.  You can bet if we ever need an equipment stand it will be yours, without question.  Nice execution of the best isolation idea out there.”
–Gerald Rinyu, Audiophile and Audio Elegance James River Collection Owner.
"The Audio Elegance rack is now housing all of my equipment and I am hearing previously unheard background vocals and instruments from recordings that I have been listening to for 30 plus years.  Also the images have greatly improved as well as the sense of space between the performers.  This morning I played the standard Columbia Dave Brubeck, "Take Five."   The interplay between Joe Morello's drum kit and Brubeck's and Desmond's playing took on new life.  The attack of the drum was so great that I played it 3 times just to be sure I was hearing and not imagining it.  I've listened to this album for about 40 years and now it sounds better, much better then I have ever heard it.  I can't understand this because at my age I should hear less.  The Rack itself is a thing of beauty.  So this email is to doubly thank you.  My wife thanks you for its stunning beauty and I thank you for the exquisite sound."
–Ed Mendick, Long Time Audiophile and Audio Elegance James River Collection Owner.
RESERVE YOUR AUDIO ELEGANCE AUDIO FURNITURE NOW.  PRICES START AS LOW AS $499.00 FOR THE STUNNING FRONTIER SERIES AMPLIFIER STAND!  CALL 573-696-3551 OR EMAIL [email protected] FOR DETAILS.
Upgrade the quality and performance of what your turntable, amplifier, and the rest of your gear is sitting on to match the quality and performance of your gear!
Why put your audio gear on wobbly stands with plastic-laminated shelves, on a stand whose parts started life as a department store sweater display, or on a stand that doesn’t match your furniture when you can get audiophile performance and fine, handcrafted furniture all in one package?
You can move up to quality audio furniture for as little as $799.00 and have and audio rack large enough for a complete system for as little $1199.00.  The Audio Elegance range of audio stands starts with the ultra-rigid Frontier Series and includes the James River Collection of stained-finish furniture and the premium quality Dakota Collection.  Learn more at www.osageaudio.com/furniture.htm.
The Audio Elegance Audio Furniture Turntable Wall Shelf combines real furniture with audiophile performance and features not found in any other turntable wall shelf.  It is designed to handle weights in excess of 160 pounds when properly mounted to the framing studs in your wall.
The turntable platform is isolated from the frame for resonance resistance and easy, precise leveling of your turntable, and is mass-loadable with your choice of materials.
All Audio Elegance Turntable Wall Shelf selections are manufactured from solid, select-grade hardwoods and finished with high-end, furniture-grade lacquers.
Every Audio Elegance Audio Furniture product carries a full, 5 year warranty on materials and workmanship.
HOW ABOUT A HIGH-PERFORMANCE, FURNITURE-GRADE PLACE TO PUT YOUR RECORDS AS WELL?
The new Audio Elegance Audio Furniture LP Storage System is the world’s best!
Using our “stacking tier” technology as a design basis, we have created LP storage that is unmatched in the industry for beauty, rigidity, stability, flexibility, and load-bearing capabilities.
The base unit of the Audio Elegance LP Storage System can be added to at any time to create additional storage, all the way up to 8 feet in height.  ADD MORE STORAGE SPACE WHEN YOU NEED IT!
The construction design and execution is extremely rigid and stable.  No sagging shelves or wobbly legs when loaded with your precious LP’s.
A 4 foot wide by 8 foot tall Audio Elegance LP Storage System will easily hold in excess of 1500 pounds without fear of damage to the LP Storage System or risk of collapse.
Audio Elegance LP Storage Systems are constructed, finished, and presented as real, fine furniture, perfectly at home in the most elegant of rooms.
Vertical shelf spacing can be specified to fit LP’s, CD’s, books, curios, or any combination or items.  Vertical spacing can also be changed at any time to accommodate your changing needs.
As with all Audio Elegance Audio Furniture selections, the LP Storage System is backed by a 5 year warranty on materials and workmanship.
NOW, HIGH QUALITY ACCESSORIES FROM AUDIO ELEGANCE!
The same hand crafted quality of Audio Elegance furniture is now available in useful, handcrafted audio accessories ranging from solid hardwood isolation block and cable lifts to vacuum tube caddies.  All of these items also come with free shipping in the contiguous USA.  Visit www.osageaudio.com/furniture.htm for more details on these products.
ALL OF OUR PRODUCT OFFERINGS ARE SUPERIORLY RIGID AND STABLE.  ALL AUDIO ELEGANCE EQUIPMENT RACKS ARE DESIGNED FOR THE ULTIMATE IN CONFIGURATION FLEXIBILITY.  VERTICAL SPACING CAN BE CHANGED TO MEET YOUR NEEDS.  THIS MEANS NOT HAVING TO BUY A NEW EQUIPMENT RACK OR STORAGE SYSTEM AS YOUR NEEDS CHANGE.
We also offer all of our items in custom sizes and materials.  Please write [email protected] or call 573-696-3551 for information or a quotation.
Please visit our website at www.osageaudio.com or call 573-696-3551, or email [email protected] for more information and for pricing on sizes and materials to meet your specific needs.
Osage Audio Products, LLC
Hallsville, Missouri
573-696-3551
www.osageaudio.com
