SoundStage! Recommended Listener Select Optical Disc Cleaner
0 Members and 1 Guest are viewing this topic. Read 992 times.
osageaudioproducts
    • Osage Audio Products
“As a CD cleaner, Listener Select was quite impressive, removing the mixture of common household substances on my test CD without breaking a sweat. But does it actually improve sound? The difference was slight but consistent: Cleaning CDs with Listener Select seemed to remove a bit of sonic grunge and distortion from the midrange, so the music sounded clearer and was easier to listen to. Because Listener Select does a great job cleaning optical-disc surfaces, comes with a large cleaning cloth that works very well, is easy to use, and has the lowest price per ounce in the group of cleaners evaluated, recommending it for cleaning gunk off your discs is a no-brainer." –Vade Forrester, SoundStage!, May 2008. www.soundstage.com.
Recommended Listener Select Optical Disc Cleaner is the best value for disc cleaning.
We spent several months researching how to thoroughly clean a CD without leaving a residue and without causing any damage to its surface. Using the same approach to product development as with our Audio Intelligent Vinyl Solutions products, we’ve found a solution.The Listener Select Optical Disc Cleaner is a high-purity, high performance cleaner that is safe and effective for use on all optical discs, including CD’s, SACD’s, XRCD’s, HDCD’s, DVD’s, and data CD’s and DVD’s.
Listener Select Optical Disc Cleaner does not contain any type of “conditioner” or “treatment”, but is only a residue-free cleaner. It is noteworthy that Listener Select Optical Disc Cleaner comes in a large, 4 ounce bottle. Other products near the same price are only 2 ounces in size. Also, the drying cloth that is supplied with Listener Select Optical Disc Cleaner is a full 12 inches by 12 inches in size! This cloth is a high quality 3M® Micro Fiber cloth.
All of this makes Listener Select Optical Disc Cleaner the disc cleaning value on the market. Order yours today in our Online Store, or email us at [email protected] or call us at 573-696-3551.
Listener Select Record Cleaning Brushes are also now available.
Check out our other fine product lines, Audio Intelligent Vinyl Solutions, Audio Elegance Audio Furniture, and NSR Sonic Research Loudspeakers at www.osageaudio.com
Osage Audio Products, LLC
Hallsville, MO 65255
573-696-3551
[email protected]
www.osageaudio.com
