DRM?
0 Members and 1 Guest are viewing this topic. Read 1494 times.
BobC
DRM?
« on: 1 Jun 2008, 01:50 am »
So I'm trying to copy my audio files (a lot of them) from one of my harddrives to another one of my harddrives.  I keep getting an error message "Error Copying File or Folder.  Cannot copy (file name).  Cannot find the specified field.  Make sure you specify the correct path and file name".
Then my harddrive is dropped from "my computer" window.  I need to power off the harddrive (it's external) and power it on to try again.
I've been deleting the problem files, but there are several.  Not sure why I cant do this since I'm dragging and dropping.  Unless DRM keeps me from making copies?  Any suggestions?
BobC
Re: DRM?
« Reply #1 on: 1 Jun 2008, 03:14 am »
Ahh!  Problem solved (so far).  Copy / paste didn't work, cut / paste didn't work, drag-n-drop didn't work.  What did was the Edit / Move to Folder.  Not sure how that's different than cut and paste, but I'm glad I figured it out.  So I guess I can't blame it on DRM afterall.  :oops:
