You also want to place the speakers equidistant from the listening position.
d.b.
Thanks Dan,
For the info. I do use a "modified" ITU configuration with all speakers eqidistant from the listening positiion, and more than 3 feet from any wall.
I always find it interesting that people get "matching speakers" and then place the sides up on or against the wall, completley changing their tonal character.
My modification is that I have the side surrounds "directly" to the sides, on axis and not at a specific angle behind me.
All my speakers are precisely converged "on axis", with the result being very interesting.
In listening to the Gloria Estephan SACD, there are some gongas the have the "sonic positioining" of being directly behind me in a very clear and distinct way, when there are no active speakers there.
I think with a bit more engineering and production this Multi-channel Audio could really be good.
Hope they do "Diana Krall - Live in Paris". I want to see if they show restraint and keep everything where it was during the show. The regular CD does not.
Krall sings from the center and her piano is stage right.
Why spend all the dough to "recreate" when the sonic image is engineered incorrectly.
If anyone can suggest any Multi-Channel that is realistically holographed, rather than "demonstrating" that we now have rear channels and can sit "IN" the orchestra,
let me know.
