0 Members and 1 Guest are viewing this topic. Read 3352 times.
I use AQ termination for speaker cables. ......
I starting to wonder if my termination may play some part. If, say I nicked some wires stripping insulation, didn't twist it together correctly, etc could cause degredation of the sound? I used Rat Shack silver solder btw.Any tips on how to properly terminate multistrand type cables?
What about bring the strands together? Should I try to twist them, or just lay them side by side and crimp on the spade. (8TC is uses 8 stranded conductors per leg in a braided configuration)
I twisted, crimped and soldered, which appears to have been a mistake.
Solder, in and of itself, is not desirable. It is used to hold things together and prevent oxidation. Generally, always try to have a good mechanical connection before soldering anything.
Tonto--Yes HCM had the best prices I found for Terminators. I did speak to AQ Direct in order to get a discount when buying in bulk which I might do next year unless I implement my own designs.
