Cornet2 cap rolling in EQ position: a question
0 Members and 1 Guest are viewing this topic. Read 2016 times.
miter53
« on: 26 May 2008, 05:48 pm »
I finally got around to swapping out the stock EQ caps in my Cornet2 as per Jim's suggestion. I tried a Sonicap Gen I at 47nf and a Relcap RTE at 1nf, and it sounded horrible! Too much mushy bass and a heavily veiled top end. Thinking it might need some burn in time, I ran my Frybaby through it for a couple of days with minimal if any improvement. I then switched from the Relcaps to Sonicaps at 1nf, and voila!, it sounds better than ever. Is the RTE just not a good choice for this spot, or might there be an issue with mixing two different types of caps in the EQ spots?
frankford1
Re: Cornet2 cap rolling in EQ position: a question
« Reply #1 on: 27 May 2008, 12:08 am »
some caps take over a 100 hours to break in. I keep having to remind myself of this because at one time two weeks ago I wanted to throw the cornet II out, Now I can't quit listening. jmho
mingles
    • my system
« Reply #2 on: 2 Jun 2008, 09:34 pm »
What caps are you using in these positions:
C203
C200
C206
C208
miter53
« Reply #3 on: 3 Jun 2008, 04:28 pm »
C208 - Mundorf SIO
C203 - Russian FT3 teflon
C200 & C206 - Sonicap Gen I
mingles
    • my system
« Reply #4 on: 3 Jun 2008, 04:56 pm »
How is the sound after a couple of days of settling in?
You have me worried, b/c your other caps are top notch.
What does the rest of your system look like?
miter53
« Reply #5 on: 3 Jun 2008, 08:03 pm »
I think it sounds great! Although the Mundorfs are pricey, the Sonicaps are pretty reasonable, and the FT3s are downright cheap. I have a Technics 1200 TT, which will soon have a ZYX RS-50 mounted on it, a DIY Cinemag SUT, Bottlehead Foreplay III pre, SAE 2200 amp, and Ohm Micro Walsh speakers.
