0 Members and 1 Guest are viewing this topic. Read 8538 times.
is there any problem with this structure that would make it unsuitable for this purpose?
should my room ideally have a concrete floor or a floating wood floor?
since I don't need any isolation for the benefit of others, and any isolation would only benefit me by keeping outside noise out, is it advisable to completely isolate my room from the walls of the structure?
I'd go with whatever floor you already have.
Properly treating a room is hardly a bandaid. It's a piece of the puzzle - proper room, proper setup, proper time control - they're all pieces of the puzzle.
...since you have ground below and nothing in terms of massive surfaces as in normal home construction, the cavity between them is pretty much effectively infinite in terms of bass buildup for the walls and ceiling
IF DONE PROPERLY, a floor system can add some feel and a bit of absorbtion without causing issues.
I'm going to try to push for about 27 feet of length
I'd contact Cardas to ask what is meant by "leaving the back of the ceiling open to an insulated attic."
I wanted the ceiling to be special. My concept had been to have a ceiling that started low behind the speakers and increased in height as it went back... Richard explained that there were a few problems with that approach, due to pressure zones.
Yes, trying to use the pole barn framing would be a PITA. And building it independently inside the pole barn gives you a huge decoupled structure/airspace. You'll probably need a concrete foundation of some sort for frost heaving and to keep burrowing vermin out anyway, so the concrete slab (with inexpensive commerical carpet) is the obvious choice IME. For the outside I'd side with T-111 (4x8 sheets of textured wood siding) and roof with 29 gauge metal pole barn material (on a slope just in case of leaks in your pole barn roof). So here's another reason to try the "Golden Trapagon".
How is it that heating/cooling is "free"? You'll need some sort of venting, even with a well insulated/sealed space. Mold can overtake an unventilated space is just a couple of weeks, leading to a total loss. And make sure you tell your homeowners insurance company about the room.
