Amperex 6922 PQ pinched waist.. how do these look?
0 Members and 1 Guest are viewing this topic. Read 1796 times.
yooper
« on: 23 May 2008, 03:56 pm »
http://cgi.ebay.com/SET-OF-3-AMPEREX-6922-GOLD-PINS-PQ-MATCHED-DATE-RARE_W0QQitemZ260243061503QQihZ016QQcategoryZ7275QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
I'm thinking about bidding on these tubes, but don't know if the tested numbers look good, what do you think?  Any experince with the seller's quality of tubes?
While I only need two of these for my Dodd, if the price is right... I'll buy the lot of three.
Mark
alotaklipsch
Re: Amperex 6922 PQ pinched waist.. how do these look?
« Reply #1 on: 24 May 2008, 07:11 am »
They are NOT pinchwaist
 :duh:
pbrstreetgang
« Reply #2 on: 24 May 2008, 07:20 am »
Dont look pinched to me but tubes and early (right after pinched) with D Getters and will have great attributes if they are good and Im concerned with the sellers description
Listens2tubes
« Reply #3 on: 24 May 2008, 02:35 pm »
Now you need to delete this thread so not to have us all bidding against each other.  :duh:
Vinnie R.
    • http://www.vinnierossi.com
« Reply #4 on: 24 May 2008, 02:51 pm »
I had to do it  :oops: :oops:...
I've been testing all sorts of NOS tubes with the Isabella, and I don't have these yet...
Vinnie
alotaklipsch
« Reply #5 on: 25 May 2008, 03:58 am »
Vinnie
Vinnie, email me if you wanna try exotic 6922's, I have many.
yooper
« Reply #6 on: 25 May 2008, 04:31 am »
 :duh:  and I thought you guys were my friends!!  :bawl:
Seriously though... I really do appreciate your help.  I wont be bidding on these as it appears I may be better off continuing my search for the sure thing.
Thanks guys, you may have saved me money and regret.
Mark
pbrstreetgang
« Reply #7 on: 25 May 2008, 04:32 am »
Me too Vinnie I have most all Amperex (no pinched- to me they arent worth it) Siemens, Mullard, Ediswan, ect
jon_010101
« Reply #8 on: 25 May 2008, 04:52 am »
These don't look too good to me at all ... the metal deposits on the glass visible near the bottom are a sign of heavy use.  Plus, I have found that Amperex PQs tend to be prone to noise after long use (at least, all 6 of mine are too noisy to use).  I basically refuse to buy used 6DJ8s/6922s at this point, since they are such a "risky" tube noise-wise.  JMHO!
If you can, try to find some that are new in box!  I've found a lot of bargains that were 100% new :thumb:
FWIW, I have about 60 6DJ8 tubes right now, new in box ... I sold all of my non-noisy used Amperex for <$10/each, and put the noisy ones in a box for "testing" purposes or for sticking in old test equipment.
« Last Edit: 25 May 2008, 05:54 am by jon_010101 »
pbrstreetgang
« Reply #9 on: 25 May 2008, 05:07 am »
got any more to sell?
jon_010101
« Reply #10 on: 25 May 2008, 05:53 am »
Nope -- I just have my "private reserve lifetime stock" at this point (and a bunch of noisy junk tubes) :thumb:
