What do you think ? ( two or three part question ). RWA , Dodd, Quatro Vanders.
0 Members and 1 Guest are viewing this topic. Read 874 times.
Mariusz
Hi everyone
To get quickly to the point here it is:
Q. 1.
Will Red Wine Audio Sig. 30 (Omega version) work with DODD Audio battery powered preamp???
Q. 2. Since Vinnie's phone is busy (I m sure that he is a busy man) is it possible to reconfigure Sig.30 to work as a monoblock amp. ??? If yes, what is the cost and benefits. Getting 70.2 is out of question but adding another Sig.30 is within my reach.
Q.3. Will RWA Sig.30 (or two) be able to drive my beloved Vandersteen Quatro speakers with enough authority without being underpowered???
Thank You for your opinion and input
Mariusz
« Last Edit: 23 May 2008, 02:39 pm by Mariusz »
Mariusz
Any thoughts . One would think that battery preamp should work with amp that is based on the  same principle. Yes,  they are not exactly the same but the benefit of going completely off the .....you have to admit -  more offten then not "noisy power lines,  especially true in the City like NY .....must be beneficial to anyone serious about his/her stereo system  performing at its best.
Sure , it is not  a recipe for the great rig but I am positive that it won't hurt either.
Vinnie from RWA and Gary Dodd are really  onto something special.
 will one work with  the other?  .........I guess , I will have to wait for my Dodd and try it myself.
As to the question of possibility of Sig.30 as a monoblock.......anyone knows of heard about it?????
Asking for comparability with my Quatros was IMO .....to naive. How many guys can possibly have similar or the same setup. :duh:
« Last Edit: 23 May 2008, 04:46 pm by Mariusz »
miklorsmith
Vinnie would probably be the best person to ask your questions.  He is very busy - I'd guess your luck getting him to answer would be better on his circle.
