SAS Audio 7A line preamlifier first beta review is in. Superb
0 Members and 1 Guest are viewing this topic. Read 1535 times.
The first review of the premium 7A is in, and I am quite pleased.
Pastor Bob,
"At the price point, I do not believe it can be touched. With that said, even with price not being a consideration, the 7a can stand tall in a high dollar system and never embarrass itself. It only suffers…and then very little, in comparison to units that are in the absolute upper echelon such as the SAS 11a."
http://www.sasaudiolabs.com/review4.htm
Features include:
The 7A has 3 inputs and 1 output jack. Optional input and output jacks available.
Extremely low distortion, typically .015 or -74db down total harmonic distortion, without any global feedback.
Can drive 20k and higher input impedance amplifiers.
Simplicity of the signal path. "Lead to lead connecting" (copyright©) whenever possible.
No frequency dependent musical/signal feedback through the power supply since only one, high bandwidth, high current, low output impedance response stage is used.
DC regulated filament power supply
Tube damper
IEC receptacle for AC power cord rolling.
A robust 4 stage power supply provides better isolation from hash and interference from/through the rectifiers, transformer and AC line, for a cleaner, more open sound.
Power Line (AC) power reversal. One can choose the better sounding position.
Premium model uses sealed selector switch and sealed balance/volume controls, Jenalabs cryod wire in the signal path.
Specs:
Frequency Response:                                         10 - 25 khz (+0, less than -.1db, 100pf, 100k load)
Gain:                                                               19db gain, approx.
Total Harmonic Distortion at 2 vrms:                    0.015% or less. (typically 74 db down, No global feedback)
Signal Polarity:                                                  Inverts
Input Impedance:                                              25k ohms
Min. Amplifier Input Impedance:                          20k recommended
Tape Loops/HT bypass:                                      Special order:
Line Inputs:                                                      3 (additonal special order)
Preamp.Outputs:                                               1 standard (extra can be ordered)
Line Cord Length:                                                6 feet standard
Dimensions:                                                        17 3/4" wide
        19" black rack front
        4" high
        11" deep
Actual Weight:                                                     14 lbs.
Shipping Weight:                                                  (Charged 30lb rate because of box dimensions)
One can obtain more info at:
http://www.sasaudiolabs.com/pream7a.htm
Take care.
« Last Edit: 8 Jun 2008, 01:16 pm by Steve »
