BRYSTON DAC
0 Members and 1 Guest are viewing this topic. Read 2250 times.
splittailz
BRYSTON DAC
« on: 22 May 2008, 04:10 pm »
This may have been previously discussed, I searched but did not find.
What is the retail price going to be on the new DAC?
  • The Demo is Everything!
    • http://www.bryston.com
Re: BRYSTON DAC
« Reply #1 on: 22 May 2008, 04:11 pm »
Hi,
$1995 US/Canadian Suggested Retail.
james
splittailz
Re: BRYSTON DAC
« Reply #2 on: 22 May 2008, 04:46 pm »
thanks James
splittailz
Re: BRYSTON DAC
« Reply #3 on: 22 May 2008, 05:52 pm »
James, considering I am slightly "dumb" for lack of a better word, on DAC hookup  The DAC input would connect to the CD/DVD toshlink or RCA Coaxial connector out correct? then connect to the preamp CD 2 channel input? My Mac multiplayer says it spins a CD 4x overspeed, would this effect whether or not a DAC could be used with it?
thanks in advance for the info.
Re: BRYSTON DAC
« Reply #4 on: 22 May 2008, 05:58 pm »
Hi Split,
Correct you can use the toshlink or the RCA Coax (I recommend the Coax) into the Bryston External DAC and then the DAC feeds the preamp input with either the RCA or XLR analog outputs on the BDA-1.
The 4 times speed is not an issue.
james
Charles Calkins
Re: BRYSTON DAC
« Reply #5 on: 22 May 2008, 06:04 pm »
When will the DAC be available?
                            Cheers
                            Charlie
Re: BRYSTON DAC
« Reply #6 on: 22 May 2008, 06:10 pm »
                            Cheers
                            Charlie
Hi,
We start shipping next week but the first 2 production runs are pre-sold.
james
splittailz
Re: BRYSTON DAC
« Reply #7 on: 23 May 2008, 12:09 am »
thanks james. I'll talk to my dealer.
Crimson
Re: BRYSTON DAC
« Reply #8 on: 23 May 2008, 12:21 am »
Hello James,
When might we see info/specs on the standalone dac on your website? Specifically, does it include a USB input?
Thanks.
Re: BRYSTON DAC
« Reply #9 on: 23 May 2008, 12:47 am »
Hello James,
Thanks.
Hi Crimson,
I have the preliminary lit and some specks - email me and I will send it to you.
james
