What impedence out should I use for SM6.9(& other models
0 Members and 1 Guest are viewing this topic. Read 1902 times.
nickyoyo
Can someone help me out on this?
I wonder why all the nOrh speakers listed in their website
do not have this spec.?
For some of the power amp which have diff. imp. output
(4ohm/6ohm/8ohm), it is difficult to decide which one to
connect if it never specify even in nOrh website :?:  :?:  :?:
lo mein
Re: What impedence out should I use for SM6.9(& other mo
« Reply #1 on: 22 Oct 2003, 12:10 am »
Quote from: nickyoyo
I believe other than the 6.6 (4 ohms), all others are 8 ohms. I have SM6.9, Prism 3.0 teak, 4.0 ceramics.
Hope this helps.
PJ
« Reply #2 on: 22 Oct 2003, 02:50 pm »
Irregardless of the speaker, set it to 8ohms.
All the other settings do is place a resistor in series to limit the current. The resistor limits the current, but WILL affect the sound for a multitude of reasons.
Peter
« Reply #3 on: 26 Oct 2003, 01:37 am »
Since you both have been posting about this beginner speakers in years I hope that you some day can afford some good speakers.
Best regards,
Peter
PJ
« Reply #4 on: 26 Oct 2003, 11:27 am »
And I hope you get banned (again) for that comment.  :nono:
rosconey
« Reply #5 on: 26 Oct 2003, 12:12 pm »
peter -this isnt your circle its m barnes(heard rumors he was kidnapped by space aliens for anal probes and such-lol)
your comment was in bad taste :nono:
