Sub connected at speaker level - effect on impedence?
0 Members and 1 Guest are viewing this topic. Read 1565 times.
nodiak
I've been using 8 ohm main speakers for awhile and am thinking to try some bipoles that are 4 ohm nomnal.
Does the sub I have connected at speaker level effect the impedence the amp sees? (~ Like having 2 pairs of speakers in parallel?) I haven't worried about it with 8 ohm speakers, but maybe should for 4 ohm.
I know I could go 16 ohm on the bipoles but I want the efficiency of 4 ohm.
Don
mgalusha
Re: Sub connected at speaker level - effect on impedence?
« Reply #1 on: 21 May 2008, 02:32 am »
I believe the speaker level inputs on most (all?) sub amps are much higher impedance than your speakers and should have no impact.
KS
« Reply #2 on: 21 May 2008, 03:06 am »
The sub has its own amp, so the speaker wire signal isn't powering the sub driver, it's just a signal to the amp.  It is not like you have the sub and main speaker driven in parallel.
nodiak
« Reply #3 on: 21 May 2008, 10:44 pm »
Thanks guys, that's good news.
Don
IronLion
« Reply #4 on: 21 May 2008, 10:47 pm »
I recently tried this out for my setup (speaker level inputs to sub) and it works very well.  No issues at all with the amps.
