Bugle as active low pass filter
0 Members and 1 Guest are viewing this topic. Read 1619 times.
Adinoto
« on: 18 May 2008, 03:38 am »
Hi,
Due to Bugle is customizable, I just wonder if it might be used as active low pass filter?
I need filter for my bass modules which need to be filtered at around 200-300Hz.
Maybe just used first two opamp so the gain is not too much?
Thanks in advance
Adinoto
hagtech
    • http://www.hagtech.com
Re: Bugle as active low pass filter
« Reply #1 on: 19 May 2008, 02:43 am »
I usually prefer to do such a thing in a non-active manner.  If you can live without gain or impedance buffering, just use an RC.  Otherwise, you can make the Bugle do just about anything.
jh
