IRIAA Question
0 Members and 1 Guest are viewing this topic. Read 1312 times.
Martyn
IRIAA Question
« on: 15 May 2008, 05:05 am »
I have several SACDs that are SACD only, i.e. there's no two-channel layer. This means that I can't rip them to my hard disc using a conventional CD ROM drive. The best solution I can think of is to connect the L and R analogue outs from the SACD player to an IRIAA Filter, connect the IRIAA to a Ripper, and then to my hard disc via the Ripper's USB.
I already have a Ripper and the IRIAA is a modestly priced kit that will come in handy from time to time. Here's my question: the IRIAA has 50 and 600 ohm inputs and -40 dB and -60 dB outputs. Forgive my ignorance, but what are the implications of these? Which does one use when? Thanks,
Martyn
hagtech
Re: IRIAA Question
« Reply #1 on: 15 May 2008, 04:50 pm »
You can almost always use the 50 ohm inputs.  Especially with an SACD player.  The 600 ohm in an optional input for very old audio generators - if you're doing reference level plots of equalization accuracy.
The -40dB and -60dB outputs are for MM and MC phonostages respectively.  You would use the -40dB for a RIPPER.
jh
