Cheap JBL waveguide gives Excellent Performance
0 Members and 1 Guest are viewing this topic. Read 11040 times.
ttan98
« on: 15 May 2008, 03:38 am »
Those who are interested(I am) in designing OB using waveguide, there is cheap waveguide from JBL, model: PT-F95HF, which costs less than $10 that gives Excellent performance. There is no point reporting here findings here go to
1.  DIYAudio under Speakers: B&C Compression Driver and Horns for discussion starting post no. 66 onwards.
http://www.diyaudio.com/forums/showthread.php?s=&threadid=122717&perpage=25&pagenumber=3
and also at
2. Audio Karma, Econo-Waveguide speakers
http://www.audiokarma.org/forums/showthread.php?t=150939
Happy reading.
scorpion
Re: Cheap JBL waveguide gives Excellent Performance
« Reply #1 on: 18 May 2008, 02:01 pm »
ttan98,
Very good links. Thank you !
I am still interested in your DE10 project, this is also an alternative for the horn/waveguide ?
/Erling
ttan98
« Reply #2 on: 18 May 2008, 03:34 pm »
Hi Scorpion,
I have 2 ongoing projects, the 2nd one is the MTM plus woofer, I have not had much progress on this project. If you are refering to the tweeter yes, I use B&C DE10 compr driver and ME10 horn. This combo need some equalization.
Another alternative you may like to try is DE10 and JBL horn ie PT-F95HF, $10 each, this combo you also need equalization, the x-over freq is around 2.5Khz not less than 2Khz, this is the limitation of DE10 not the horn. If you have more money try De250 it is very good.
Sorry it is very late here I going to bed. If you need more info  leave a message here, catch up with you tomorrow.
Cheers.
Saurav
« Reply #3 on: 18 May 2008, 04:09 pm »
Do you have any measurements of the DE10/ME10 combo? Kevin Haskins is bringing a speaker with that tweeter to VSAC, I'm looking forward to hearing it. I might try it on my next set of speakers.
ttan98
« Reply #4 on: 19 May 2008, 03:03 pm »
I have it in printed form but my printer/scanner is out of action. sorry I cannot leave info here.
Saurav
« Reply #5 on: 19 May 2008, 05:49 pm »
Can you describe the results qualitatively? How peaky was the on-axis response in the lower treble, and how was the rolloff of the highs? How did the off-axis response look?
panomaniac
« Reply #6 on: 19 May 2008, 10:11 pm »
... there is cheap waveguide from JBL, model: PT-F95HF, which costs less than $10...
Hey TTAN98 - where the heck are you finding these for less than $10??  I've never seen a JBL horn that cheap, ever.
Can't even find an online seller for this or the bigger 12x12" version.
Kevin Haskins
« Reply #7 on: 19 May 2008, 10:22 pm »
Right now it sounds..... just 'ok'.    I'm not sure it is the fault of the driver/horn combo though.   I'm fighting with the midrange--woofer crossover.
Saurav
« Reply #8 on: 19 May 2008, 10:50 pm »
Hmm, OK. Well, I'm still looking forward to hearing it :)
dweekie
« Reply #9 on: 19 May 2008, 10:55 pm »
A little summary from the other thread.
http://www.audiokarma.org/forums/showpost.php?p=1856214&postcount=228
ttan98
« Reply #10 on: 19 May 2008, 11:02 pm »
I don't want to repeat(takes too long) what have been said on the about sites(2) I am referring, I am repeating what has been said. Zilch is kind enough to get a pair for me as I am living overseas.
If you read the thread closely you will find a JBL site where you can place order, ie in the States.
panomaniac
« Reply #11 on: 19 May 2008, 11:10 pm »
Thanks - found it - I think.  Looks like the JBLPro parts dept.  Seems to be orders by telephone only.  Might give it a try. :)
ttan98
« Reply #12 on: 13 Jun 2008, 12:06 pm »
http://www.audiocircle.com/index.php?action=gallery;area=browse;user=42260
The above is the measurement(on axis) I obtain from using the combo, Selenium D220Ti and JBL econowaveguide. the details of my set-up is as follows:
I use DCX2496 set with the following parameters:
1. 2nd order LR HP @ 2Khz
2. High Pass shelving set at 17.5Khz @ 3.5db gain
the 2 sets(left and right) look pretty close, see Attachment. The next step is to integrate with the JBL woofer in hand. Looks pretty good for a $55/combo.
