0 Members and 1 Guest are viewing this topic. Read 2982 times.
All my FLAC stuff is on a Dell Poweredge 600SC right now...works fine, but it's too damn loud. No surprise I guess, because it has a power supply fan, a 120mm rear case fan, and an 80mm fan in front cooling the hard drives. Those three sources of noise are going to be what I attack first...does anyone have any suggestions on very quiet fans (both 120 and 80mm)?
would you possibly be replacing more loud parts with quieter versions?
Quotewould you possibly be replacing more loud parts with quieter versions?Exactly.I'm on a pretty limited budget, so buying something else completely isn't really what I'm looking to do right now. Unless it's under $100 or so
Sorry to be redundant, but what do you use your computer for mainly - is it mostly music / file-serving / business apps?
Does it also has a CPU fan? Often it's the noisiest. How many hard drives and what's the CPU?
I can't remember if it has a CPU fan. Just a single 250GB right now, probably going to a 1TB this fall though. Processor is a 2.4gig P4.
