Audio/Video Gear and Systems
The Lab
sts9fan
Mute Switch on Aikido Pre ?
0 Members and 1 Guest are viewing this topic. Read 1304 times.
Gvt1911
6 May 2008, 10:16 am »
Finishing off my Aikido preamp and would like to add a mute switch. Do I install as "usual" with outputs shorted to ground?
JoshK
Re: Mute Switch on Aikido Pre ?
7 May 2008, 12:07 am »
Email Broskie. I think you can short the output to ground after the cap, but I am not 100% sure about that.
2wo
Reply #2 on:
8 May 2008, 06:37 pm »
Yes, you can put the switch in after the output cap…John
Gvt1911
Reply #3 on:
8 May 2008, 08:21 pm »
Thanks Guys !!!!! aa
The Lab
sts9fan
