Promitheus TVC sold
0 Members and 1 Guest are viewing this topic. Read 1389 times.
kck
Promitheus TVC sold
« on: 5 May 2008, 06:39 pm »
This is the four-input, two-output version. Dark red wood sides and bottom, shiny metal top. It is in excellent shape with only a couple of minor scratches in the top which are not noticeable unless looking closely. The wood sides are also in very good condition with some scratches on the bottom.
I bought this from well-known AC member Ryan Tew and have used it off and on in a couple of systems over the past year. In each case it has rendered the music in a very pure manner. Now I am settling into a system which uses an integrated source and preamp (Slim Devices Transporter) so this will serve someone else better.
There is a small, and to some, inconsequential glitch. On volume setting #6 (out of 22 I believe) one of the channels (I think the right) cuts out. This happens ONLY on this volume level and only in one channel, which tells me it is probably a loose connection and therefore an easy fix for someone who knows this stuff, which is NOT me. Correct me if I'm wrong but looking at the way this is wired I don't think this can 'contaminate' any of the other volume settings. In any case this happens very low down on the volume scale so unless you have massive gain in your source or some other unusual thing going on, you will do as I did and never even need to use this setting. I always played it at 9 and up. After all this thing has no gain!
Pictures will be provided to interested parties. Please read my feedback on Audiogon (link below) and be assured of a good transaction. Payment to be by USPS MO, Bank Of America cashier's check, OR Paypal if you use funds and not credit card (thereby incurring no charge to you or me).
http://cgi.audiogon.com/cgi-bin/fb.pl?user=Kck
$old
« Last Edit: 4 Jun 2008, 04:56 pm by kck »
kck
Re: Promitheus TVC
« Reply #1 on: 7 May 2008, 12:57 pm »
bump
kck
Re: Promitheus TVC
« Reply #2 on: 11 May 2008, 04:39 pm »
TVC sez:
Please adopt me! (adoption fees shown in main ad). I am looking for a good home. This owner has taken very good care of me but I do not get any exercise since he went 'commando'. I say you need a good preamp in the system but he wants to - hah!- simplify matters.
To which I say: I am the SIMPLEST thing around in preamps... all I do is switching and attenuation. I am even more transparent than GWB's eyes, so you can see there is NOTHING there (er, to mess up your sound, that is).
Please...
« Last Edit: 12 May 2008, 12:57 am by kck »
kck
Re: Promitheus TVC
« Reply #3 on: 21 May 2008, 01:52 am »
bump
