How to set up SLA Battery Supply?
0 Members and 1 Guest are viewing this topic. Read 873 times.
Fork
  • (855) JAGAUDIO
    • JaguarAudioDesign.com
« on: 4 May 2008, 10:29 am »
There's a lot of talk on this board about adding SLA power to gear, but not a lot about how to do it.
For those of you who already have yours set up, give some details about where you got your components and what the setup looks like (what kind of charger are you using and how is it and the component connected).
Can it be set up so I can keep the charger and the stereo component connected to the battery at the same time, without having to connect one or the other?  I assume you would use a DPDT switch.
I'm thinking about connecting a little T amp, but what should I know about the original power source specs to know whether a single battery is sufficient?
