Eastern Electric MiniMax tube Phono preamp MM only SOLD! SOLD!
0 Members and 1 Guest are viewing this topic. Read 1061 times.
Bill O'Connell
  • Retired . Music Lover
This used phono has a bad step up transformer meaning you will not be able to play any low output moving coil cartridge :(, however the good news is that if your running a MM cart or a high output MC(you would have to use the MM section anyway for a high output MC as you wouldn't use the step-up transformers).It carries the same 2 year warranty. This has a wonderful MM section and I guarantee you will be happy. :D $750 to your door.
 Bill
« Last Edit: 8 May 2008, 06:50 pm by Bill O'Connell »
